Results 1 to 10 of 10
Thread: Need catalytic help ASAP!
    PA
    Default Need catalytic help ASAP!
    I am switching from OEM catalytic converters to a magnaflow 94008 2 in 2 out. Currently my o2 sensor sits on the top side of the catalytic converter but toward the frontal area. so my question is, the 94008 magnaflow doesn't look like it has a hole for an O2 sensor. So where should I have my mechanic put the O2 sensor? Pre cat? After cat? what gives?
    What to do?
    id guess you should put it in the same general area. Maybe you should compare the innerds of a stocker in comparison the the aftermarket and try to place it in the same general area, if your onn an inch and its not in the correct spot you might have problems. Do your research before drilling away!.
    it needs to be pre cat and only reading one pipe won't hurt anything, i have the 02 mounted in one of the collectors of my e30s headers and it only reads 3 cylinders, just pick a safe spot where it's out of the way and weld in a 02 bung in one of the head pipes
    PA
    Winfred, theres no harm in putting it a foot in front of the cat then and in one tube? Also, wouldn't that mean i could run no cats and the car wouldn't even know?
    one tube and a foot forward would be fine, the only cars that care about the cat are obdII cars 96 and up with pre and post cat sensors
    PA
    Thanks winfred. i don't mean to question your knowledge but it seems everyone is telling me i need an x-pipe and to put the O2 sensor in that? This is un-needed right? I just want to clarify for final.
    i've yet to have a problem with my car (e30 with headers) or any of the other cars i've done, a x-pipe wouldn't hurt and the sensor would be seeing the whole engine
    Oct 2007
    The purpose of the x-pipe is to balance the sound for dual exhausts (especially if the pipes are not close together).
    Indiana
    Yay thread revival! Welcome newcomer.
    PA
    wow this was 2.5 years old. That's so funny.
  1. Catalytic Converter?
    By lilcallaway in forum 5 Series BMW
    Last Post: 02-21-2009, 07:16 AM
  2. E39 Catalytic Converter
    By IGordy in forum 5 Series BMW
    Last Post: 09-06-2006, 05:00 PM
  3. Catalytic Converters
    Last Post: 01-20-2006, 07:31 PM
  4. catalytic converter
    By pong in forum 5 Series BMW
    Last Post: 03-03-2005, 01:14 PM
  5. Catalytic...How do you know if it is bad ?
    By pineman in forum 5 Series BMW
    Last Post: 08-27-2004, 09:02 AM
