All you do is push the stalk towards the side you want to be illuminated.You have to push it all the way to the stay on indicator position,one sront parking light (left for you I spose) and one rear tailight only come on.You dont have any other switches onHow does one set the blinker stalk to remain on
I took a while to figure this out too!You start with the wipers in the off position,push once to the intermittent position and almost immediately turn em off again.You return to the intermitent position after the desired intervalthe proper way to set the intermittant wiper timing
does that clear the dash obc display ????or you can just push the check control knob in the dash
ps Geoff where did you get your clears?
