Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: What Does It Do?
    Sep 2004
    Quote Originally Posted by Qsilver7
    ...if you haven't programmed it...or if the previous owner programmed it but the car's power (battery) has been disconnected...the programming has been lost. You must have the full featured OBC to use this function. You also can choose any or all of the OBC info to display...personally I only programmed HR/DATE/AVG MPH 1/RANGE.
    To program the BC functions, turn ignition to position 2, then:
    1. push the turn stalk in towards the steering column and hold for apprx. 3-5 seconds until PROG 1 appears in the instrument cluster display.
    2. press the desired (OBC) info button(s).
    3. Press the S/R button on the OBC when finished
    If you have an owners manual..this info is in there under REMOTE CONTROL.
    Thanks. Tried this several times - PROG 1 never appears. Any other suggestions? FYI - the OBC works fine.
    Atlanta
    For the wipers try it this way:
    In one motion press down for a single wipe & then go up to the INT position and return to off. Go back to the INT position after the desired time. You should notice a difference in interval although there is a max duration you can't seem to exceed.
    I tried and tried the manual method and never made it work. This has become a natural motion now--although trying to explain it to the wife sux.
    Philly, PA
    I believe the parking light on function only works if you have a euro LKM. Maybe even need other parts as well.
