Thanks for the comparison shots. It's always good to see the result before you spend your cash!
How does it compare with the original setup?
Is the ride noticeably harsher... would you say uncomfortable by comparison?
Of course the standard wheels and tyres will help the ride anyway.
I'm considering whether or not to go with the Sach kit or maybe Eibach's with Konis. I believe the Sach kit uses Boge (Gas pressure?) shocks with Eibach springs - is this correct? I was trying to find out more about Vogtland springs but they don't appear to be available in Australia. The local Koni distributor only lists the Koni Sports shocks (Yellow) for the E34. The standard Koni Reds don't appear to be available. They do a Koni suspension kit with the Koni Sports and Eibachs. I would really prefer to drive an E34 fitted with that combination before I make a descision - Cheers
