Results 1 to 7 of 7
Thread: Limited slip differential
    Nov 2004
    Orlando Florida
    Default Limited slip differential
    Hey Guys,
    I have the opportunity to buy a 4:10 lsd and I am thinking about putting it in my '90 535 ( automatic tranny ). The current lsd is a 3:65 ( or so ). I know the car will probably be a real neck snapper off the line but I am concerned about how much the cruising capabilities of the car will suffer? Will I see something like 4000 rpm at 70mph? Are there other considerations that have to be addressed when making this conversion? I am hoping the considerable wealth of your cummulative experience will provide what I need to make an intelligent decision.
    Thanks in advance.
    Gordo.
    Check KMS's site on this (http://www.koalamotorsport.com). Brett's got a good article on the diffs of diffs. I was doing the exact same calculations on my car last night.
    My '90 535iA has a 3.91 LSD (cold weather package). At ~ 70mph, I run about 2900 RPM. If I put in a 4.10, I go up about 300 revs, to about 3200.
    Not that bad, but I'd rather just keep the current gearing and save the money on gas.
    Best, whit
    San Luis Obispo, CA
    You should have a 3.91 in your 90 535iA. I am going with a 4.27 lsd in my 90 535iA and I don't think it will be anything close to "a real neck slapper" after the swap. I am hoping it won't be as much of a lard arse off the line that it is now. As for the revs at cruising, remember these cars were designed to cruise at 100 mph + so while it will be turning a little faster it won't be unacceptable. Good luck.
    multiply your rpms at any speed by 1.126 and see what the rpms will be with the 4:10.
    be about 4500 at 100 mph according to Dereks sig pic.
    Central NJ - USA
    i went on my 90 535i auto
    from 3.91 to 4.27....this car
    is chipped...
    some difference, but not much around town
    highway is just some more revs
    used to be 3 grand 80mph now its like 3300 or so?
    Feb 2005
    brisbane
    here is the easiest way mate, use this gear ratio calculator. http://www.unixnerd.demon.co.uk/revs.html
  1. Replies: 6
    Last Post: 02-19-2007, 06:15 PM
  2. 3.64 limited slip?
    By epj3 in forum 5 Series BMW
    Last Post: 05-09-2005, 09:00 AM
  3. Recommended oil for a 4.10 Limited slip differential?
    By atomicDog in forum 5 Series BMW
    Last Post: 01-01-2005, 02:44 PM
  4. Winfred, how about a limited slip for the 318iS?
    By Jr ///M5 in forum 3 Series BMW
    Last Post: 08-10-2004, 08:23 AM
