Results 1 to 3 of 3
Thread: Idle Vibes - Engine Mounts?
    Feb 2005
    Plymouth UK
    Default Idle Vibes - Engine Mounts?
    I have a 1992 520i (M50), runs smooth when not idling and I have no excessive engine movement, from what I can see but I get a fair amount of vibration when idling. Is it worth renewing the engine mounts? Has anyone done this and noticed any significant improvement?
    Nov 2004
    Split, Croatia
    Quote Originally Posted by Triv
    I had the same problem - when I cleaned the injectors and changed spark plugs the idle was much smoother (EAT chip helped, too).
    I changed my engine and trans mounts some months ago and there is no more vibration in idle and also the shifting seems to be smoother (can also be my imagination).
    At the same time however I started to use also STP gas treatment and water remover to clean the valves etc.
    So maybe all worked together. But in any case the change of the mounts helped. But they are oil filled, so you can usually see when they are leaking. There will be some 'mist' of oil on the outside.
    It is a bit harder to do the job on my V12 engine, so it should be no problem for you to do it.
    But in any case, as Interceptor said already, all other parameters must be checked before hand.
  1. Replies: 3
    Last Post: 02-27-2009, 08:08 PM
  2. Engine mounts ay...
    Last Post: 05-31-2008, 08:57 AM
  3. M60 engine mounts
    By e34musician in forum 5 Series BMW
    Last Post: 09-06-2007, 07:31 PM
  4. M50 engine mounts
    Last Post: 09-04-2007, 08:15 AM
  5. M60 Engine Mounts
    By stargazer_61 in forum 5 Series BMW
    Last Post: 07-02-2006, 07:51 PM
