Thread: What oil weight is recommended for rear....
    No. California
    Default What oil weight is recommended for rear....
    differential? Stopped by Pep Boys last night to pick up Red Line injector juice and bought 2 bottles Castrol Hypoy C 80W-90 gear oil.
    Wanted an opinion on what is recommended or others use.
    Thank you
    Kurt
    95 525ia
    synthetic 75w-90 or use the 140wt for LSD units.
    Jun 2005
    Cleveland, OH
    Pep Boys sucks.... Not that it adds anything to the discussion
    I miss my e34
    Benneton (United Colors of)
    castrol hypoy c is unsuitable for this application, as, as regal said, it calls for a synthetic oil. the 80w numbers up front usually only come with conventional gear oils, not synthetics. depending on what the diff tag says, you need a 75w90 or 75w140. mine is quite happy on royal purple 75w140 with a tube of LSD additive thrown in so i wouldn't have to do it twice. it should cost you between 8-14$ per bottle for suitable stuff, and you need two bottles.
    Lexington, Kentucky
    Default requires synthetic
    Believe it states so in the manual. My indy has changed it for me twice. I think he used redline.
    Quote Originally Posted by KurtM
    Thank you
    Kurt
    95 525ia
    synthetic is a given, the rear gears are so small that they would literally wear out in under 100k with reg lube.
  1. weight distribution E32 front rear axle
    Last Post: 02-23-2008, 06:48 AM
  2. Recommended E34 for student.
    By t.wak in forum 5 Series BMW
    Last Post: 07-05-2006, 09:15 AM
  3. Recommended octane??
    By mr.winky in forum 5 Series BMW
    Last Post: 08-03-2004, 09:45 PM
  4. Recommended engine oil for E34 with M50?
    By Rick L in forum 5 Series BMW
    Last Post: 03-27-2004, 07:46 PM
