Bruno's website is a good info for that too
http://www.bmwe34.net/e34main/upgrade/suspensions.htm
A shaky ride lead me to look at my shocks and the driver's side front is leaking. Time for some new ones.
I don't want to change the ride or stance or anything, just get it back to good.
Okay, now what? BMA has a couple different Boge shocks. Is doing the fronts without doing the rears an exercise in stupidity?
And springs...do I need springs? I have close to 160k miles on the car, I'm assuming original springs though I don't know for sure. I can't even find springs for this car anywhere, though I haven't looked too hard. Again, will doing the fronts without doing the rears cause me problems?
TIA
Dave
Hi Dave.
You might find some useful info in my recent sachs kit install:
http://www.bimmer.info/forum/showthread.php?t=9792
http://www.bimmer.info/forum/showthread.php?t=9850
I would definitely do the rears if your fronts are of the same vintage and are leaking.
springs are a nice addition while you're taking everything apart. Might as well do it all right the first time, eh?
Best, whit
yeah but do springs actually "wear" out????I have mtech suspension and i can see the time is coming...but i thouht i would keep the springs??
As long as your ride height hasn't changed; no - your springs haven't worn out.![]()
Dunno on the Mtecs, and it's hard for me to comment on the OEM 535 ride, as mine had to be replaced the second I bought the car...so it's hard for me to say what was the strut's fault and what the spring was doing.
After 220k, I was convinced that the average automotive spring would lose some of it's rate of return/tensile strength. I guess the ultimate test is ride height, but my shocks were so dead that they weren't exerting any pressure, which contributed to my situation a lot.
Best, whit
Yep. You'd expect they'd get a little softer over time, but whatever happens - the end result is 'sagging' - and if they aren't sagging there's no problem.Originally Posted by lowell
Shocks do exert a little bit of upward force, so changing them will probably fix most small 'sagging' issues.
