I know most mentions of lack of correct bleeding revolve around over-heating.... I have over cooling - my temp gauge never reads 12, always the tick before that, so I read through the advice here and assumed a bad stat (I've already replaced it but with a cheap one) so I just bought a new stat from the dealer and installed it and still same problem. One thing though, my thermostat cover's bleed screw is jammed in tight and the nut is worn away.... I tried with WD40 and pliers and various things and I just could not get it loose, so I can't bleed from the stat housing - is an air bubble there likely to be causing my problem? I'm going to call the dealer today and see if they've got a new cover in stock (I ordered in and got a new bleed screw but I cannot get the old one out at all).... do you think that will solve it or am I barking up the wrong tree completely?
Thanks
Doogie
