Which would be easier on the engine, 1 water decarbonizing or 6 lo-spd ita. tuneups?
have done an eye-talian tune up during each work shift for the past week (once the engine has been running for at least 1 hr). is this being too hard on the motor if i do it 10 or 11 times? my procedure is to just drive around town for at least one minute with the car locked in first gear at 45 mph (yielding about 5200 rpm). it has netted me some extra power (and raised the pingband from 2100 rpm to 2300 rpm) but has yielded no additional mpg. the very strong chemical i've been running in the gas for the last 50 gallons or so has raised the pingband from 1700 to 2100, and gotten me an additional 1mpg in real BS proof stop and go (ie, 14.5 mpg to about 15.3), but no additional power. keep in mind that i'm not running synthetic right now, so that might factor into the "abrasive" value of the italian tuneup. thanks.
how do you pour it in there?
I used to do this with the old carbureted engines with unbelievable results
even with a bigger hose the chance of
hydrolock is virtually impossible unless your idling at 300 rpms. In other words if it starts to die stop the water from flowing. Do not have it attached before you start it and make sure it doesnt siphon when you shut it off.
Ryan, the reason i don't advocate that is with the ventil
sauber the procedure is to stick the vacum line into the can of cleaner and run it until the engine sputters and dies, all the while its smoking like crazy , then you're supposed to let it sit for awhile so it soaks into the carboned up parts and after a half hour or so start it and run it until it quits smoking... by this time the epa will be on your ass they smoke so much when you do this..
At any rate when you suck the fluid straight in like the from a port in the bottom of the manifold the fluid follows the path of least resistance and goes mainly to the center cylinders and the cylinders at the outer ends get almost none, so not much cleaning effect there.... Then secondly when you use this solvent to clean all the carbon out and let it hot soak, you dump a carbony solventy mass all at once into the catalytic converter which then does its best to immolate itself possibly leading to a catalytic converter meltdown and failure.... The problem with water is that the method of cleaning that it uses is called thermal shock meaning the water hits the piston top and the combustion chamber top causing them to cool extremely rapidly and shrink which is how the carbon breaks loose and flakes off...
Aluminum pistons and cylinder head surfaces don't always like this , Cracked ring lands can occur from thermal shock.... I personally think you'd be better of using a can of the bg cleaner designed to remove carbon deposits from the valves, combustion chambers and pistons... They have fuel injector cleaners and then they have carbon deposit cleaners , not always the same thing... You just run them through on a couple of tanks of gas and its a slow gradual process that doesn't overload the cat or cause any other possible harm.
Quote:
Originally Posted by ryan roopnarine
i already had the rail type service done before, i can't afford to keep having it done until my ping is gone. i'm thinking that if i can tap a closeable hole in the air intake boot and insert water right at the throttle body, i can get a more thorough clean. if i get rid of the ping, ill buy my uncle a bottle of the bg fuel rail cleaner and get him to hook the car up when i go down to ft lauderdale to get a r12 refill, so i won't have to do anything that drastic ever again. right now, i'm somewhat smitten with how quiet the engine has gotten (and strangely, how lighter the steering has gotten)...that i'll give it a try at a better location in the intake path.
