finally installed the door handle gaskets with a few hitches
The rear ones went on okay, I mean fine but the front ones are a different story. I purchased them from kenneth woo in malaysia a long time ago and finally gto around to putting them on. for the front handles though, they won't go on properly, it seems that that they aren't exactly the right size, I tried using warm water to make the rubber more workable but when I went to install it on the drivers side, its on there now, the door handle won't open, the rubber around the keyhole dosen't align perfectly neither does it for the pins go on the handle.
on the drivers side i removed the handle sorround incorrectly so I broke one of the tabs off which I will have to replace now. Both front door handle surrounds are very difficult / impossible to put on while, the rear gaksets are on almost perfectly.
there have been a few posts about this before. (The first thread is a really good one - http://www.bimmernut.com/forum/showt...+handle+gasket) I realise why now.
I took about two hours to install the front passenger gasket without luck, while the two rear ones, took 30mins in total for two.
