is it un-advisable to spin an engine backwards?
I'm certainly not talking about spinning it over backwards with a reversed starter motor or anything like that, more along the lines of lining up torque converter bolts, adjusting valve trains, et cetera. I've heard this advice for the second time last weekend, with the explanation that in timing belt driven cars, one does not want to reverse the tension while under load. can anyone clarify or dispel the advice i received? thanks.
The advice you received is accurate,
you don't want to turn a timing belt equipped car backward or for that matter any timing chain equipped car that has a tensioner. They can jump a tooth and in the case of a chain bunch up or break a tensioner or guide rail. Sometimes it unavoidable but you want to avoid it whenever possible.
Quote:
Originally Posted by
ryan roopnarine
