Check valve lives with the fuel pump, in the tank
The fix kit from BMA is an inline valve that goes on the fuel line, under the access panel in the trunk
The valve keeps the fuel system pressurized so starts are a snap.
The check valve is originally in the top of the fuel pump but
when that one fails you can use the inline as a replacement. The check valve keeps the line pressurized all the way from the fuel pump up to the injectors, this prevents vapor lock from ocurring since the boiling point of the fuel is much higher when its under 35 psi than at atmospheric.. So it serves 2 purposes , 1 to ensure that fuel is right at the injectors when you first crank it, and 2. to prevent vapor lock from occurring in the fuel line
Quote:
Originally Posted by 2fast
Ok Guys I have a hard start problem when warm or hot so I thought I would try the Fuel check valve,I have a few questions.
Were is the old check valve does it have one?
Can I get this part at my local store or do I have to get it at BMA?
I sent BMA a email for a price and shipping cost to New Zealand.
What does this check valve do.
I had a look at
http://www.bmwe34.net/e34main/trouble/535ihot_start.asp
a pic from Bill's archives
http://www.bimmernut.com/%7Ebillr/im...checkvalve.jpg
I think the p/n is no longer up to date, latest one should be 16141179282.
Copy that. It might be and it is not the first time that local parts store will look at you funny when you ask for it.
Shogun the part number that you quoted is the original check valve which screws into
into the top of the fuel pump... thats not the in line repair that they came up with.. In order to install this one you have to pull the pump out since its the original check valve.
Quote:
Originally Posted by shogun
The term vapor lock still applies to the fuel injected car, you're
thinking that lock means to lock from starting and it doesn't. A vapor lock is strictly a bubble in a liquid line similar to the terminology air lock. Vapor locks on fuel lines with the old mechanical fuel pumps you referred to could occur while it was running causing the car to stall, they could occur after a hot soak as you mentioned, they frequently did occur at the suction fuel line since that was a low pressure area if it passed over a hot spot such as a resonator or exhaust pipe.. a large number of them vapor locked in the steel line coming from the mechanical pump on a v8 up to the carb after it was shut off and hot soaked. These vapor locks didn't always keep the car from starting and they frequently just required long cranking to get the car to start.... On the fuel injected cars the check valve fails , fuel boils in the lines at the engine and fuel rail, fuel is pushed back into the tank and a vapor lock in the line occurs, anybody that has worked on any fuel injected cars that this has happened too can tell you that it doesn't take just a second or 2 to clear, frequently you crank it for 20 or 30 seconds before it will start , acting very similar to the same vapor lock conditions on an old carburated car.
Quote:
Originally Posted by SRR2
Right. We're in violent agreement. I wouldn't be a bit surprised to find vapor in the engine fuel rail if the check valve had failed. In fact, I'd be surprised if there weren't vapor there! My point, and I think we're on the same page, is that because the system is pressurized from the tank, it can't "lock" in the classic sense of the concept of "vapor lock" which is why I mentioned the Lincoln fiasco. Anyway, at worst, it will take a second or two to purge the vapor as the pump pushes enough fuel into the rail to recondense it and/or push it back into the tank.
I think this has been a productive argument. I bet there are at least one or two members who understand the role of the check valve a little better than they did before.
Fuel delivery rate is about 2 qts/min at 12 V / ...
3 bar counterpressure, and only pushes fuel for a couple seconds at key turn before cranking, so if the check valve is bad, and fuel line dries back to the fuel tank and keep fuel vapor only, you have a nice time starting the engine.
Javier
Thats typical of either a bad check valve in the pump in which case the
number that shogun gave you will work if you pull the fuel pump out and replace the original check valve... It can also indicate a couple of other things such as leaking injectors which would also allow the fuel pressure to bleed down and would tend to make a hot engine flood so that it would take a little more cranking to start... If you hold the gas pedal all the way to the floor on a hot start does it start easier than if you give it no gas, If yes then that tends to indicate that its a leaking injector (1 or more) causing excess fuel in the manifold , causing a flooding condition which you have to crank until it clears, by holding the pedal to the floor it shuts the injectors off while cranking... this is the clear flood mode.... If holding the pedal to the floor doesn't help then its a bad check valve or a bad pressure regulator.., you can test to get a basic idea first by putting a fuel pressure gauge on it and cranking it to see how high the pressure goes and then letting it sit and see how quickly the pressure bleeds down... It should hold with virtually no leakdown for at least 1/2 hour min. IF it does leak down then you can pinch off the return line coming from the fuel pressure regulator back to the fuel tank and check again to see if it bleeds down, also remove the vacum line to the pressure regulator and see if any gas comes out of there. If these things make no difference then it narrows it down to fuel injectors leaking or check valve leaking.
Ok I have not ordered the part yet.
Here are my symptoms.
when cold car starts BANG!1 second.
When warm or hot may take 3-4 seconds embarrassing.........But not always
Sometimes it start fine when hot.
What do I do feller's.
Check valve? as in part 12 of the link below? .....
should be a piece of cake.
Check valve
Javier
