Here's the story. Rather than painting my hood, I decided that I would just replace it as it would probably cost the same amount. I've tried searching online to no avail. Does such a thing exist?? Can someone help me out?? Thanks.
gamjohn2
Printable View
gamjohn2
Not sure why you think it would cost the same amount as repainting your existing hood- especially since you can't find a CF hood.
I'm sure they're out there- somewhere, but I don't think you'll find one for $200 like the CF Honduh hoods..................and then there's shipping cost which could easily be $200 itself.
Bret.
Bret is on the money about the cost. Even a new hood is cheaper than a C/F one. Then with the C/F one, you have to be careful about the paint or the clear, you need a hood prop and cannot use the shocks to keep it up, and hopefully the fit and finish is good.
There has been talk about installing an e34 c/f hood and even group buys, but for some reason, not many e34s have them...if they even do. That is for a reason. No good companies have taken the task of making an e34 hood and those that have have charged large amounts of money. I remember of one M5 that has it, but he is in europe.
If you are talking about cost, then go with the stock one. You have to also factor in problems later that you will have to pay for any corrections a c/f hood may need.
http://www.sotechsystems.com/store/i...wCat&catId=212
found this but no E34,maybe they could help
I've found a lot of sellers of CF hoods for a 89-93 e34 for under $500. Not that I have actually checked into it, but I would assume that a repaint of the hood would run higher than that. I just find it odd that there aren't any for the 94+ model years.
Here's an example - http://octanemotorsports.chainreacti...roducts_id=916
gamjohn2
they show up here once or twice a year usually around $500, they are usually for 89-94 525/535/m5 cars as those are the most common, the 93-95 v8 and 95 525 with the wide snout are much less common, and uglyer :D
Wouldnt you sitl have to get the CF hood painted?
unless you wanna play ricer and never paint the body kit you installed last year
Quote:
lolQuote:
Originally Posted by winfred
CF hood on a 525,,,,why??
