Dinan makes an a/t chip for $200. Get that along w/the EAT.
Quote:
Originally Posted by jplacson
If you're not after top-end speed... then forget the blowers. they just add weight and don't do much for acceleration (which is why BMW stays away from them in their M-cars)
Superchargers are much better for take off speed than turbos however. Since air pressure is already applied at all revs.
Actually, from E34.net, the best you can do is swap out your differential. This will alter your ratio and give you a lot more power at low speeds. It lowers your top end, but boosts your 0-60 a whole lot.
Headers would also do your 0-60 good, so look for good ones. I heard Racing Dynamics make really good ones for the E34
A chip does wonders. But more so for A/T since it reprograms the way the tranny shifts as well. It basically maximizes your engine. Stock chip is good as it is, but is tuned to cope with varying octane levels. Upgraded chips work well with only higher octane fuel. Switching to standard octane will make your car more sluggish if you run an upgraded chip.
