Quote:
There are lot's of different spring manufacturers, the most popular are:
H&R: Moderately stiff ride. (1.3" front - 1" rear)
Eibach: Moderately stiff ride. (1.3" front - 1" rear)
Racing Dynamics: Slightly stiff ride. (1" front - .75" rear)
Bavarian Auto: Close to stock ride. (1.3-1.5" front - 1" rear)
Dinan: Sport spring that almost doesn't lower the car.
M5 springs: front works with any E34. Rear will not work unless you have a self-leveling suspension.
Sach "sporting" kit: bodge turbo gas/Shach spec Eibach springs, not as stiff as the bilstein/Other spring combination. (1.25" drop front). It seems that on the 540i, it created a drop of 2" front and 1.25" rear...
What shocks with what springs, form the less stiff to the stiffer ride:
Original ride: Original springs or Bavauto springs with Boge
Slightly stiffer ride: Original springs or Racing Dynamics springs with Bilsteins HD.
Moderately stiff ride: H&R or Eibach or Racing Dynamics springs with Boge.
Moderately stiffer ride: H&R or Eibach or Racing Dynamics springs with Bilsteins Sports/HD.
Adjustable stiffness: Dinan stage I (tiny drop) or use Koni shocks (expensive).
Basically if you want to lower the car and keep the OEM ride, go with the Bavauto springs.
