Airborne, think about his statement a bit
you take 20w50 and heat it up to 210F which is the standard testing temp and it will pour like water. You take 0w30 which is thicker than water at room temperature and chill it down to 0 degrees or colder which is the cold testing temp and it will thicken up or pour much more slowly. Put some in the freezer overnight if you want to see for yourself. And then watch hot 20w50 draining out of your engine on an oil change. You'll see what they're talking about.
The concerns on here regarding synthetic leaks are greatly exagerrated. i wouldn't be too worried about changing to it.
If your going to stick to Dino , then i'd probably run a castrol 10w40 in the winter where your at.
Quote:
Originally Posted by Airborne001
HUH? How is it going to pump better cold if it is thicker?
I had originally planned to switch to SNY oil, but this site totally changed my mind on the subject due to problems posted on this site with SYN causing leaking. I am not a total wrenchead by any stretch of the imagination, and don't want to get involved with having to replace gaskets at this point.
Given that we only sometimes see temps below +10F here, what Dino oil would be the best for the winter?
