gale suggested getting a longer bolt and doing that but I can't easily fit a puller.. this wheel has no place to bolt onto itself... if In had a shop I might,might be able to make a plate to fit into where the airbag bolts in but that isn't even within sight at the moment.. I looked for a bolt at Lowe's yesterday and no luck. 16mm bolts aren't falling out of the sky..
http://home.comcast.net/~cpkver8/images/Swheel1.JPG
Also if anyone can tell me what that white plastic clip is for I'd appreciate it.. I was able to budge the wheel a millimeter or so and that clip was then catching on the spline teeth so I had to remove it.. what is its function? Some sensor relating to steering wheel position? Lock? Air Bag deployment?
