Originally Posted by Brandon J
I would say, forget what you hope others do for you. See how your car handles and keep on observing. You were right with the e34 to get the shocks, again I don't understand why not now. It really goes against everything you learned just because someone else says it will work. Well, it will work, just how well and how well in the long run.
As far as sport package e39s, many only do subtle upgrades with the sport suspension, thats also if they choose to do a suspension upgrade. They may do swaybars. Some have tried to swap in Konis, but the factory sport suspension is about 1" (give or take) taller than what would work best for the konis. I have the sport suspension from the factory. The best upgrades were the swaybars. Then getting good tires. I opted for the sticky PS2s as well as using wider tires used on the M5. It is much more balanced with the 245s in the front. The ride is very nice, I mean very nice and compliant. I am also running 275s in the rear. Before the larger tires, I autocrossed the e39 and so the testing of before and after the swaybars were done.
One note, I am wondering how many people here have seen a long wheelbase car like the 5-series in an autocross or a track. I have seen some amazing drivers with the 5-series and the car would sway a little. It's not all about flat corning, it's more so about carving in the turn. Look at Sabine and you will see how much the e39 sways or weight shifts. For good balance of handling and ride, there needs to be a resonable amount of sway because of the long wheel base. It does help carve the turn. If the sway isn't there, then the front will push, or oversteer. Now to combat you can add camber plates and sway bars. So, the main point here is if the springs are too stiff and your corning is too flat, then the 5-series will not carve as well. Have you ever felt like a car has a place where it sits on a big turn and it just sticks?
Qube, I hope things go well for your supension. I simply go by the rule of if you stat from scratch, why not do it right. So, if you are doing your suspension, why not do it right. You know the suspension would have been complete if the springs and shocks were done well. So thats why I ask why did you not trust what you and everyone else knows. My only assumption could be that you wanted the look, or you did go cheap, or it was an impulse buy. Good luck and I hope it works out well for you.
