When my center bearing failed...
...the driveshaft would grind against the heat shield above the resonator/exhaust. It would grind loudest when decelerating.
And quiet down mostly on accelleration. All center bearing failures don't sound the same, it depends on how bad it is. Its a $30 part and a few hours of labor, not real hard, just time consuming.
That would be the most common failure anyway, could be the other things people have mentioned also.
Quote:
Originally Posted by pyro
explain what your grinding noise was. was it only when starting from a stop? I think it may be the same thing with me (thats what my firend said) also i think the trans mounts could be shot to. Ill give it alook
