I'm guessing that he doesn't, GM after 2/91 does not have a dipstick.
1
Quote:
Originally Posted by uscharalph
Do you have an ATF dipstick on your car?
Thats the date that bmw gives in the tis for the gm's without the
dipstick, i'm assuming its the car build date but maybe not... do you have the pan with both plugs in it? if so someone may have installed a dipstick in yours. or if not someone may have replaced a bad transmission with a used one from an earlier model.
Quote:
Originally Posted by ryan roopnarine
my 7/91 1992 525i has one. im assuming, bill, that you are speaking of the build date of the tranny, not the car.
Since you have the dipstick you just push the top of it sideways in the
direction of the arrow while pulling it out. Then you can check the fluid like you would on a normal one. And you add through the dipstick hole as well.
Quote:
Originally Posted by ArtemLepilov
My car does have a dipstick in it for the ATF but its one of the black ones with an arrow - i couldnt get it out (was afraid of breaking it if i pulled too hard.) But now in a few hours im going to fill it up with fluid. I will let everyone know how it turns out...
Thank you all, Artem
