If your dual mass is hosed, stuff an E28 unit in. Lighter (approx 32 to 22lbs) and resurfaceable. About $50 to $75 for a flywheel. If you do the job, you'll want do do/get this:
- E28 flywheel
- E28 clutch kit
- E28 flywheel to crank bolts
- Plan to replace your rear main seal while you are in there; so simple at that point.
If you want the gold star, rebuild your shifter linkage at the same time. Bushings, T, mounting points, all that. Good time to toss in the Z8 shifter arm ($60) for a shorter throw.
Jeff
Been there, done all that.
