Thanks. Tried this several times - PROG 1 never appears. Any other suggestions? FYI - the OBC works fine.Quote:
Originally Posted by Qsilver7
Printable View
For the wipers try it this way:
In one motion press down for a single wipe & then go up to the INT position and return to off. Go back to the INT position after the desired time. You should notice a difference in interval although there is a max duration you can't seem to exceed.
I tried and tried the manual method and never made it work. This has become a natural motion now--although trying to explain it to the wife sux.
I believe the parking light on function only works if you have a euro LKM. Maybe even need other parts as well.
