E34 Door panel re-install question
I'm getting ready to replace the driver's side door panel on my 1995 525iT (power window motor died) and noticed that the black plastic retainers (which includes the clip that presses into the door to hold the panel onto the door), have come apart from the door panel. Is there any kind of glue that anyone has used to successfully to re-glue the black plastic retainers back onto the door panel?
Couldn't have been that easy...
Quote:
Originally Posted by atomicDog
Actually, that's not the particular clip I'm talking about. The black plastic clips actually surround the door panel and have a white clip protruding out that attaches to the door. The black clips are attached to the door panel with some sort of yellowish adhesive. Looking at your picture, I noticed that your clips came off with the door panel as they should have. Mine didn't and need to be re-attached. What's the best adhesive to use that won't come loose?
Can't take credit for all the door panel pics, the first two are someone else's 535 I believe. Do yours look like the one below? My panels are a bit different, with fewer clips and a more solid 'anchor'. I wouldn't hesitate to recommend Gorilla Glue (see below, below pic). I used it for my door panel vinyl fix, skate ski binding fix, fiance's ring fix, etc. etc. and it seems to be a very strong glue. Just remember to follow the instructions and moisten one surface.
http://img.photobucket.com/albums/v1...pslocation.jpg
http://img.photobucket.com/albums/v1...ls_2004007.jpg
Best of luck,
Dave M
