I was checking on the voltage of the car,it was stone cold.Opened the hood and tested the voltage from the (+) post and ground,it read 12.45v.Then i disconnected the throttle position switch and here are my findings:
1-TPS/ the voltage read 4.96 from the connector,terminal 3 and ground.
2-MAFS/ the voltage on pin 3 and ground read 12.14v.
since those are crucial for the ECU,and any change in voltage could mean change in the mixture, do you think that it can be overlooked,or better carry out more testing? at least what i have in mind is to check them from the ECU for ohm reading.Any other suggestion is appreciated.
BTW/ i suspect that my car has a low voltage problem, i messed with all the ground points possible
jj
