battery drain information
Since practically every hollow space within an 8/7/5 is host to a control unit, many with memory and sensors, it is no wonder the E31/32/34 has such a high resting current drain. About 1 amp/hour drain about every 20 hours. Here's the figures:
With the trunk/luggage compartment lights off:
1.) Driver's door open: 4.8 - 5.0 Amps
2.) Driver's door closed: 4.1 Amps for 20 seconds then reduced to approx. 450-470mA for next 16 mins. then reduced to approx. 50mA
With the trunk/luggage compartment lights on:
1.) Driver's door open approx. 6.1-6.4 Amps
2.) Driver's door closed--approx. 5.9-6.1 Amps for 20 seconds, then reduced to approx. 2.5 Amps for the next 16 mins, then reduced to approx. 50mA
And remove the ignition key when engine is switched off
http://www.thee32register.co.uk/attach/94077/e32.jpg
Found in other boards and combined for your info.
