Sound System no sound but stereo is ON
My car developed a problem in the audio system. It's a 91 535ia, and all of a suden the sound stopped coming out of the speakers. If I turn the volume all the way up, i can barely hear some audio. At some point it cut off and kicked back on for another hour but it stopped working again and this time for good. I am guessing the AMP has problems. How do I go in trouble shooting it so that I don't go replacing the amp and something else is the culprit?
Al
looks like the AMP is dead
Checked the fuse and it's good, I checked the power 12 V and Negative and also control and all seem good. I messed around with the amp a little and hit it once or twice and sound came back and went away again, so I am guessing a cracked solder somewhere, but most likely won't be able to fix on my own, unless I get a diagram of the amp.
What to do next to replace it? I want to keep the stock radio and changer, so just need to replace the amp, do I get a used one or is there aftermarket ones that I can use.
Al
Looking for an original AMP "Blaupunket" 91 535i
