Just changed my thermostat
After looking at various things about the cooling system, it seems my needle should always read 12 o'clock.... since I bought the car it has been about 1/4 of the way up (except for when it was overheating due to air in the system!), so I changed the thermostat at lunch time (drilled a hole in the new one at the 12 o'clock position which had an indent mark for where to drill anyway)
Hopefully that'll solve that problem, and possibly help with my other problems!
So, so far since I bought the bimmer I've gone from knowing *nothing* about working on cars (ok, I did fit a high level brake light to my old mini with a vampire connector thing, lol!) to having changed my stat, coolant, temp sensors (blue and brown) and the water pump (including snapping the bolts in that and having to grind down to the block and drill out!)
Well, at least I'm learning something!
Drilling a hole in the t'stat I believe is covered in...
bmwe34.net and also Winfred has advocated this as well by drilling a 1/8" or 1/16" (can't remember which) hole at the 12 o'clock position to speed up bleeding. I installed a t'stat recently and didn't drill a hole but bleeding surprisingly went pretty fast.
Quote:
Originally Posted by bimmerd00d
i'd love to see a pic of the PDA sat-nav setup. Also, what is the story behind drilling a hole at 12:00 in a t'stat?
