M30 Overheating Problem Diagnostics
Ever since changing coolant this year I have been experiencing overheating. I suspeceted the obvious and ever since have , bled, bled, bled, bled, bled, and re-bled the system, all to no avail. Just checked it again and there really doesn't appear to be any air in the system.
Now I';m beginning to suspect the fan clutch, but when I test it cold, it spins with slight resistance.
Here is my first question - With the engine hot (but turned off) should there be noticeably more resistance spinning the fan by hand? It seems to have about the same "slight" resistance hot or cold. Plus, while the engine was running, I watched the fan as I increased RPM's and I didn't see or feel any additional air flow under the hood. I would assume the fan should have increased air flow as I increased RPM's - Right?
Thanks in advance for your help and advise.
MB
