George, I suspect that his definition of sway is not the same as yours or mine, I
thing that he's referring to swaying back and forth as he drives down the road.... Kind of like accerating with a 500hp 2500lb car on a wet road... where the rear end wants to move from side to side... If the subframe bushings are gone it will want to do this causing you to make steering corrections more often than not.. It makes it feel like you punched it on a dirt road with bald tires...only not quite that exagerated. If you ever drove a muscle car with a broken leaf spring mount you'll know the feeling.. Thats the first thing i would look at is the subframe mounts just to see if they are shot.... If he's talking about sway as in body roll going around corners then I'm all wet..
Quote:
Originally Posted by George M
If you are referring to rear sub frame bushings being shot...not a big contributor to swaying. Aside from sway bars and modest contribution due to spring rate...the shocks on your car are a major factor. Would say that stock shocks typically will go about 80k miles on these cars prior to replacement...some run them to over 100k miles....so you are getting close if you want ideal performance. Other thing you can do is opt for thicker sway bars front and rear...at some compromise to ride quality...but not as much as opting for stouter shocks to control sway in corners.
HTH,
George
