E31/E32/E34 control and thrust arms
OK, by p/n cross-referencing, I've come to the conclusion that:
- E32/E34 share the same control (lower) arms
- E31/E32 share the same thrust (upper) arms
What I wanted to know is:
- how are E31/E32 thrust (upper) arms different from E34 ones?
- how are E32/E34 control (lower) arms different from E31 ones?
Is it possible to use E31 control arms on E32/E34, since they use the spherical bearing instead of a rubber bushing like the latter ones? I want to stiffen my suspension and make it a bit more responsive by using thrust arms with 750i bushings and control arms with spherical bearings, if possible.
This page doesn't make it very clear:
http://www.bmwe34.net/E34main/Upgrade/Suspensions.htm
