1 Attachment(s)
What do we have here? - Coolant Show
1989 535i
Minor coolant show on the engine block below the intake manifold - notice what seems to be a trail of coolant flowing from above the oil dip stick.
No more than 1/4 oz - I wipe it clean once a month or so.
Perhaps the water pump gasket, tstat housing?
Any ideas?
Blair...
Check the upper radiator hose connection at the
Quote:
Originally Posted by
angusbn
1989 535i
Any ideas?
Blair...
radiator. I had a very similar path on my 535 and thought it was coming from the t-stat too. Turned out fluid was running along the bottom side of upper hose over to that area under intake #1 then dripping on the head and making the same path. Wrap a rag around that t-joint in the hose and see if it stops. Rag should start getting damp.
Good luck.
