My auxillary cooling fan not working on low speed when A/C is turned on
The high speed works jumpered directly when using the temp sensor on the rad. The low speed does not work when jumpered.
I have checked the fan resistor and it is at .8 ohms- I think this OK.
I have checked the continuity of the low speed wire - OK
I removed the low speed relay and there is no power when I check terminal 30on the low speed relay.
Any ideas?
