OBC Temp drop when headlights on
This is driving me crazy - the outside temp display will drop 10-20 degrees whenever I flip on the park and/or headlamps. I've cleaned 3 ground connectors (2 on drivers side front fender, 1 on pass. side front fender), all wire insulation looks intact (that I can see without tearing things apart). As long as the headlights aren't on, the temp display is accurate.
I've searched the forum with no luck, any suggestions?
Mike
1989 525i 214K
Re: OBC Temp drop when headlights on
Quote:
Originally Posted by Ross
It's cooler at night!
True, but I only use the headlamps during the day, and wear my sunglasses at night:p
I'll check the voltages this evening if I have the chance. About 80 degrees F here in No. Va. right now, let's see how low I can go - got it down to 7 degrees last night.
