Got to replace radiator and condensor...anything else? (and A/C ques.)
Ok, so I'm gonna order some parts from BMA, and wondering what I should get now that I've got some things to do.
I've gotta replace the radiator cause on my last flush a couple months ago, I had to replace the upper rad hose and upon removal I realized that the plastic neck on the rad was snapped (aargh). I tried to mickey-mouse the new hose on utilizing what was left of the neck, and it holds...for now. It's slooowly oozing out and will probably blow anytime. So because that plastic crap neck is part of the whole shebang, new radiator is in order.
Also, I did some A/C work a bit ago. Found that I had a leak at the low press hose from evap to compressor, and also a trace amount around the expan valve. Replaced those, buttoned it all up, evac and recharge and came out ok. 2 months later suddenly blows warm again (damnit). Now it seems it has got some holes in the condensor and again trace amounts around the evap area.
I know, I should've replaced the evap when I was right there replacing the expan valve, but my cheap ass wanted to save a few bucks...oh well, gotta tackle the thing again.
Ok, so here's some questions:
1. Do I have to replace the drier? I know that everytime you open the system you should, but I put a new one in only a couple months ago.
2. Should I replace all the other a/c hoses just in case (comp-cond, cond-drier, drier-evap)? They seem to be holding now, but who knows, maybe a few more months of pressurizing an 18 year old system might take its toll?
3. Since I'll have the rad and condensor out, should I replace anything else? I'm thinking at least all the belts. The water pump was replaced about 7 years ago, the thermostat about 4.
The cooling system works great, she holds dead center even in 90 degree-heated traffic, I just need to replace that damn radiator cause of that broken neck.
Thanks a lot for your help all, this forum is priceless! Don't listen to that douche that was bitching earlier, I've accomplished more than I can say with the help of the people on this forum!
Aloha,
Wes
