OT: Bill R. Code scan results...
Hi Bill,
The code came back as cylinder #2 misfire. I figure the potential components in this chain are spark plugs, HT wires, coil pack and ignitor. Am I missing anything? Cam & crank sensors seem a long shot.
HT wires are new so I'll replace plugs. Would you advise anything else?
Adnan
Adnan, that should be a code po302, if thats the case then here's
subaru's starting point list... down at the bottom... also on codes like this its possible that it was randomly generated and after you clear the codes it won't come back... if it does then you know you have a problem
http://www.bimmernut.com/%7Ebillr/images/suba1.jpg
Quote:
Originally Posted by Adnan
Hi Bill,
Adnan
