Suspected Leak in heater.
G'day everyone.
I've been loosing a fair bit of coolant recently, just yesterday i'd had enough and put her up to check the hoses. nothing. however when i turn the heater on (very rarely atm) there is a strong coolant smell (even when i use the fan without the heater) my question is this.
If you have a heater core/pipe leak can you still loose coolant even if you don't use the heater or fan?
Also what kind of fittings are best for a bypass, there was discussion of it recently and someone said about copper/brass fittings being bad for the coolant system, should I get grey iron fittings instead?
