Pulled car in garage and radiator expired...
Talk about good luck!
Pulled into the garage and PSSSHHHHTT!
Glad that didn't happen out on the road!
The upper radiator hose nipple on the radiator basically "disintegrated" (for a lack of better terms).
It just gave way and cracked, allowing coolant onto the fan and begin slinging it all over.
Time for a radiator...and upper/lower hoses....thermostat and gasket....
Water pump looks/feels tight as well as fan clutch.
1. Do I REALLY have to remove the fan and clutch to get radiator out?
2. Couldn't I just release the shroud from the radiator and lay it back over the fan?
3. Then slide the radiator out...and the new one in?
That SOUNDS logical.
Any input from previous experience is GREATLY appreciated.
The heater hose "nest" looks like a real project...
Quote:
Originally Posted by Anton CH.
No need to remove the fan for radiator removal. Your logic seems correct.
There's quite a mess of small hoses on the M50, isn't there.
Goodness.
I'll be calling BMA today, folks.
Thanks for all the input!
Change it all while you've got the radiator out
My water pump went on the MASS turnpike on a 95 degree day. Took 3 hours of stop and start to get home. Make sure you get the metal impeller pump. The pump is easy to change it out especially if you have the radiator and fan clutch removed.
Everybody talk about t-stat housing. Think this ....
apply to 525i, wich is this case, and not to 535i / M30. Isn't it?
