::.. Installed LEDs Yesterday
I did the rear because it's the easiest to play with the wiring.
Took both tail lamps out and reversed the contacts for Signal and Brake. Tested and of course got the fast blinker and brake light warning.
Crimped in a 6ohm for each circuit and everything works fine. It's quite bright in day and just beautiful in night.
Oh, I had to clip the inside of the bulb holders slightly so that the LED bayonets can go in fully and seat properly.
Time required: 15 minutes
Actual time spent: 30 minutes
It took me extra time because I had to 'extend' several wires because they were too short to swap around.
Brake light:
http://autolumination.com/images/aut...56_t1_r_wm.jpg
Turn signal:
http://autolumination.com/images/aut...56_t1_a_wm.jpg
Crimp on 6ohm:
http://autolumination.com/images/led..._equalizer.jpg
Before you ask how much I spent... I spent nothing. I am now a distributor for autolumination.com and it was part of the starter sample pack.
What I want to do now is use the following bulb for the FRONT indicators after I figure out how to 'reverse' the wiring for that:
http://autolumination.com/images/aut...whiteamber.gif
It's white regular running and switched to amber when signalling.
Also, I need change the high-mount (center) stop light to LED as well... as soon as I go in and figure out the wiring.
