Thrust arm torque. Different approach. Good?
Copied over from thread "Torque thrust arm bolts. Jack stands, ramps, other?'
Different approach but if poster is right it seems only way to go. What is wrong with his report. This was on the e28 board "mye28.com". Front suspension design is about the same with lower control arms interchangeable, if memory serves.
I'm going to post this here and open a new thread with it, because if it's right it needs a full review.
You will need to reset the Toe anyway. Just wait & tighten them while it's on the alignment rack. If the shop you go to won't let you do that, (or tighten them for you) don't go there. ;-)
(My method from last week)
"Gene said: Dick, why, do I need a FE align? What changed? Certainly practical way to torque. "
I say: Any suspension work/component replacement will affect the alignment.
In my case the toe-in Increased by 0.17" or about 3x too much. 0.080-.090 is about right. Mine went to 0.250" w/ new thrust arms.
It's your tires.
