1 Attachment(s)
opened up windshield washer pump
the lower part, to where the hoses connect comes out first ,by prying on it with 2 screwdrivers opposite one another.
this will expose the metal impeller wich slides of the motor's axle. then u have to remove the 2 parts of the motor housing. pullin' realy hard should do the trick , but in my case having 2 bandaged fingers that hurt a lot didn't help much. so i used a screwdriver, positioned it where the 2 halfes meet and wacked it with a wrench. Having the motor out i realised it wasn't burnt it was just siezed , because of water getting to the brass bushing and coroding it. some wd-40 and moving it bach and forth solved that.
yet another shameless ad for eBay
Quote:
Originally Posted by skr
i used wd-40 to get the axle moving in the bushing, not for lubrication
In Aus, new pumps (#61661380068) are like USD$10 on eBay. My problem with this part is the resovoir seal (bung), not the motor shaft seal in the pump. On my car the pump is ok, but the bung slowly lets the water out of the resovoir, trickling onto the ground overnight. Was going to seal it up but then figured I might as well buy a new pump too when I do it.
Now it would be REAL nice if the pump came with a new seal like it seems to from BMW (but I can't afford that!)... maywell have to make one of them or fix the seal. Skr; perhaps we need an equally good-fix for bushing the pump grommet!! Tx :) Nick
