thrust arm bushing gone under 10k miles..........
my dreaded 55-60 shake has gotten much worse in the past month with a new clunk noise & now it is starting to feel like a safty hazard.
what else should i replace? something must be eating these up.
i only got about 1,000mi. out of the set on the car when i purchased it, so i installed a set of 750i bushings & had gotten about 15k even though i did not torque under load & this set (m5 lemforder) did not last 10k with being torqued under load.
i am planning on replacing everything wearable in the spring time, but i do not know if i can stand waiting that long.
thanks
tim s.
i am beginning to think that...............
they could be wearing out quickly due to a combination of old struts, springs, & control arms bushings. i did not replace the control arm bushings since i have alum. arms. this sucks because i will not have the cash to replace everything till february.
i am planning on new factory springs, but still debating on the 3mm thinner spring pads, (i need the near factory heigth for bad weather driving), bilstein hd struts & shocks, new lemforder alum. control arms, new lemforder thrust arms, m5 thrust arm bushings again, tie-rods, sway bar links, rear sub-frame bushings, dog bones, & a set of heavier sway bars.
as far as i can tell the struts & springs are original.
i am open to suggestions for what sway bar set to purchase.
i hope to eliminate some of the cars body role.
thanks
tim s.
i am still using the original 15" wheels.
Quote:
Originally Posted by bimmerd00d
large wheels kill the bushings. I swapped to 16" 225/55 tires and rims from 17", and the bushings lasted 80k, vs 20k with 17" 235/45
tim s.
