Fuel Pressure Regulator DIY?
Anyone have a DIY on this or can explain. Do I just unbolt the old one and hook up new one? Is this a DIY or should i take to shop. Any tips or hints i'm figuring it might get messy. Is there a lot of fuel suppose to spillout or something? I might take it to the shop if it is too messy or a lot of hassle. I'm thinking its pretty simple. How much labor should i be charged?
This is pretty much bolt off, bolt on
Just need to release the pressurized fuel in the line. Unfortunatly BMW does not have a schrader valve on the rail to easily release it. So gather up some rags, wear eye protection (gas in the eyes burns like a mother) and slowly relase them clamp on the line.
Un bolt the old regulator, replace the gasket/o ring and bolt up the new one.
Un do the clamp first at 10 or 11
This will relase the pressure. If you unbolt first, the pressure will be released at the rail/regulator junction. Not a big deal, then you could skip 10 or 11 all together. but if you are not expecting it..it could get messy. 14 is the return line not much gas should come from there.
Fuel filter replacement can be messy
and I would recommend clamps for this job. Since it is almost level with the tank and fuel could start siphoning out.
I don't pull any relays. But I aways disconnect the battery to prevent anything hot from sparking.
