Originally Posted by Jon K
As you mentioned in the last line of your write-up, the ohm load and cross over is more important than the tweeter itself for if you don't load the system enough (or over load it, eek) you will have less volume or clipping and failing amplifiers. The cross over frequency is important too because if the factory cross-overs in the amplifier are lower than what the new tweeter is designed, you won't have the high range. If it's too high, you will be overdriving the new tweeter.
