Google Search BimmerNut.com
Go Back   BimmerNut.com Forums > The Main Place To Be > 5 Series BMW
User Name
Password
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 07-29-2010, 04:09 AM
Rick L Rick L is offline
1995 525i, 2001 M3 Convert, 1997 Jaguar, 1984 Maserati
Major Contributor
Default Body roll?
Recently I replaced many suspension parts including upper control arm (thrust arm) with 750 bushings, front sway bar links, tie rods, rear pitman arms, and rear sway bar links. But after the replacment, I noticed I have noticeable body roll... Before replacing suspension parts, my car felt very planted to the road with minimum body roll. What part of the suspension would create more body roll? Everything was tighten to correct torque spec.
__________________
RICK
BMW 1995 525i (Alpine White)
BimmerNut.com still rocks, PM Me (Bimmer Nut Ed) if you have any ideas for improvement
Get a $10 discount plus Free Shipping on orders worth $199 or more at Auto Parts Warehouse. Use this code upon checkout (TENAPW)
  #2
Old 07-29-2010, 05:54 AM
ArnZ! ArnZ! is offline
Gold Coast, Australia 1988 BMW e34 535i 308k kms
Big Time Poster
Normally worn out sway bar links and such cause more body roll as there is more play in those parts thus letting the body roll more then it should. Most of the time getting thicker sway bars reduce body roll.
__________________
  #3
Old 07-29-2010, 01:19 PM
BigKriss BigKriss is offline
Sydney, Australia - 09/1988 E34 535iA M30B35 256,000 kms
3 Grand Master
Send a message via AIM to BigKriss Send a message via MSN to BigKriss Send a message via Yahoo to BigKriss
i would say shocks first, springs second
__________________
  #4
Old 07-29-2010, 03:13 PM
genphreak genphreak is offline
1988 BMW E34 euro 535ia Exec 265kkm
3 Grand Master
The only thing you've replaced that can affect that markedly is the pitman arms and the front bushes. Even when worn, the swaybarlinks don't have enojugh play to do more than rattle and twank. Check your tyre pressures first
__________________
08/88 535i e34
M30+miller MAF, 'Stiens, Tints & Teeth!
WTB: e34 manual pedalbox, shifter, boot, clutch, mastr cyl.
  #5
Old 07-30-2010, 01:53 PM
Major Contributor
My shocks and springs are good (running Eibachs + Koni Sports adjustables). Weird thing is that it was much better before replacing these new suspension parts. Can the bushings on the new suspension parts be softer???
__________________
RICK
  #6
Old 07-30-2010, 02:54 PM
Tiger Tiger is offline
1994 BMW 540iA
4 Grand Master
Did you do alignment yet?
  #7
Old 07-30-2010, 06:31 PM
Jehu Jehu is offline
1995 BMW 540 6sp 355,275 Prod. date 1994-12-13
2 Grand Master
What kind of Tires are you running?
I recently replaced Michelin Pilot Sport PS2's with Toyo Proxes 4 and notice unpleasant body flexing during fast cornering. For instance if you're just driving straight on a highway and turn the steering wheel back and forth you can easily get the body to flex.
The suspesion parts are all OK so I was looking at the Tires. The PS2's didn't so this. The turning was crisp and precise. I was guessing these Toyos being an "all season" tire were harder than the Michelins so they transfer the forces up to the bopdy where the Michelins gave more and the forces went out the tires which may be why they wear out so fast. Well less than 20,000 miles and I was seeing thread.
__________________
  #8
Old 07-30-2010, 08:57 PM
Major Contributor
Yes, did the alignment after all new suspension parts replaced.
It can't be the tires. They are the same tires as before (Yokohama S-Drive 235/45/17 fronts & 255/40/17 rears). And I checked tire pressure and they are good. I noticed the body roll only after replacing those suspension parts so it must be related to those parts. Don't get me wrong, it doesn't drive like a Buick or anything and still handles well but not like before.
__________________
RICK
  #9
Old 07-30-2010, 09:02 PM
1994 BMW 540iA
4 Grand Master
Recheck all your sway bar links... After I did mine, everything was super tight.
  #10
Old 07-31-2010, 03:06 PM
3 Grand Master
Inspect the thrust arm bushings. If not Lemforder, they could already be bad. I refuse to use them and put up with the noise of poly ones as the fitment can't go wrong and the cheap arms all have weak bushings. Only other thing I think can do this would be your rear subframe mounts; maybe they chose to break at this most 'opportune' time. Hoping you find it quick...
__________________
08/88 535i e34
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
