Google Search BimmerNut.com
Go Back   BimmerNut.com Forums > The Main Place To Be > 5 Series BMW
User Name
Password
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 01-03-2008, 05:43 PM
Russell Russell is offline
1995 BMW 525ia 1/95
2 Grand Master
Default SRS light on for 5 minutes
Today I just noticed the SRS light stays on for about 5 minutes before going off. Bentley manual says should go off in 4-6 seconds. Happened before about 3 years ago and had to have reset by indy.
Sensor in seat or seat belt was stated as possible culprit. Believe airbags work when light finally goes off. Anyone Know for sure.
Any other suggestion such as electrical connectors. Where are the connectors or sensors? May try cleaning connections. TIA
__________________
1995 525i Auto, M50TU 2.5L, EAT chip, 1/95 build, USA, 225/60/15 tires, ASC+T, HID lights, lumbar, OBC, BMW Alpine 5 radio with BMW-Pioneer CD Changer, 186k miles, Oxford Green/Parchment
BimmerNut.com still rocks, PM Me (Bimmer Nut Ed) if you have any ideas for improvement
  #2
Old 07-16-2009, 08:12 PM
Gearhead Gearhead is offline
1995/BMW/540ia/171k
Big Time Poster
Send a message via AIM to Gearhead Send a message via Yahoo to Gearhead
Russel,
Did you ever tack this down and fix? If so, what what it? TIA
John
  #3
Old 07-17-2009, 02:38 AM
1995 BMW 525ia 1/95
2 Grand Master
Quote:
Originally Posted by Gearhead View Post
Russel,
John
Not really, I had it reset, and it came back. The seat belt latch is at fault.
__________________
  #4
Old 07-27-2009, 02:25 AM
ringle ringle is offline
Definitely the seat belt latch. Just have it reset.
  #5
Old 07-27-2009, 02:29 AM
shogun shogun is offline
11/1988 E32 750iL
5-10 Grand Master
if the latch is defective, resetting does not help much, as the light comes on again. First repair, then reset, then no more light
  #6
Old 07-27-2009, 02:34 AM
Quote:
Try resetting first as many times it solves the issue without the light returning. The latch is more than two bills new at the stealer plus installation!
  #7
Old 10-14-2009, 05:25 AM
11/1988 E32 750iL
5-10 Grand Master
Bill R. mentioned some time ago:
quote
If you look at service bulletin 720496 youll see it. Its caused by a broken or damaged circuit board in either the drivers side seat belt latch or the passengers side. If you have code 24 its the drivers side if you have fault code 25 its the passenger side, either way it goes into the default mode which is to trigger both bags in the event of an accident.
IF the system is functioning normally then the seat belt sensors detect if you have a passenger in the car and will turn that bag on or off which would save some money if nobodies on that side then you don't need to trigger the passenger bag.
It affects all models with the ZAE airbag system, e34e36,e38,e31 as of production date 3/94
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
