Google Search BimmerNut.com
Go Back   BimmerNut.com Forums > The Main Place To Be > 5 Series BMW
User Name
Password
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #1
Old 08-31-2005, 11:10 AM
A1BMW535iSport A1BMW535iSport is offline
1990 BMW 535i Sport 114k
Send a message via MSN to A1BMW535iSport
Default SRS Airbag Light - reset?
anyone know what pins in the diagnostic connector to short to reset the light, there is no fault it was triggered whilst removing instrument cluster to replace a bulb
__________________
Haynes - "Fitting is Reversal of Removal"
BimmerNut.com still rocks, PM Me (Bimmer Nut Ed) if you have any ideas for improvement
  #2
Old 08-31-2005, 12:26 PM
Kalevera Kalevera is offline
3 Grand Master
Sorry A1 -- I think the only way to accomplish the task is a) get the peake tool, or b) have someone or some place with the appropriate diagnostic computer perform a reset (autologic or modic II and higher would do the trick).
best, whit
  #3
Old 08-31-2005, 02:00 PM
brodee brodee is offline
1989 325is, 1992 525iM, 1993 525iT
Major Contributor
The normal Peake reset tool will not reset the SRS light, only the check engine light. Does Peake make one to do the SRS?
__________________
1988 M3 - Track rat
1989 325iC
1995 530iM
2000 323iT - UUC BBK, PSS9 Coilovers
2005 GMC HD Crew
  #4
Old 08-31-2005, 02:21 PM
Bill R. Bill R. is offline
4 Grand Master
Default The peake srs reset tool will only work on 94 and
newer, i bought one and it would not work on 89,90 and 91 that i tried it on.. Then peake changed their website to read 94 and up.. I called them and they agreed that it wouldn't work and refunded my money.
Quote:
  #5
Old 08-31-2005, 03:22 PM
callen callen is offline
89 735il, 2006 Cooper
Big, Big Time Poster
so what did you do? My 89 7 needs to be reset.
  #6
Old 08-31-2005, 03:35 PM
4 Grand Master
Default I sent one to a friends shop who has the snap on mt2500 that
winfred and most of the shops around here use...For myself i'm looking at some of the software based palm pilot ones that are a little cheaper, hoping to find one with multiple manufacturer capabilities...
Quote:
  #7
Old 08-31-2005, 04:57 PM
Major Contributor
Quote:
Do these work on the OBD1 cars? All I've seen are OBD2 versions.
__________________
1988 M3 - Track rat
1989 325iC
1995 530iM
2005 GMC HD Crew
  #8
Old 11-23-2009, 12:24 AM
shogun shogun is offline
11/1988 E32 750iL
5-10 Grand Master
I have one for the older BMW's, all in one tool
http://www.bimmernut.com/forum/showthread.php?t=39204
SIR3 digital (20 pin round socket) : US $85.00
This device is for resetting BMW models built from 1987 - 2003 with a 20 pins plug interface; WITHOUT can bus.
The unit resets the following functions:
Airbag / SRS Light, Service Interval, Oil Change Indication
Works on the following models:
3-series E30, 3-series E36, 3-series E46, 5-series E34, 5-series E39,
7-series E32, 7-series E38, X5, Z3 E53, Z8, Z1
  #9
Old 11-23-2009, 07:13 PM
Kibokojoe Kibokojoe is offline
89 BMW 535i 91 BMW 735i
Grand Master
Let me know what you find. I have been looking for the same thing
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
