Google Search BimmerNut.com
Go Back   BimmerNut.com Forums > The Main Place To Be > 5 Series BMW
User Name
Password
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
  #11
Old 08-23-2009, 03:38 PM
shogun shogun is offline
11/1988 E32 750iL
5-10 Grand Master
you need the complete wire system (bowden cable), see these 3 pics, one is pull out by the seat, the other one is pushed in by the seat.
Or go in ta motorbike shop and by the single parts to solder the end piece onto the bowden cable, they have bowden cable by the yard.
check the parts based on your VIN, I am not sure if you have this system
http://bmwfans.info/parts/catalog/E3...belt_adjuster/
http://img255.imageshack.us/i/beifahrersitzxf9.jpg/
BimmerNut.com still rocks, PM Me (Bimmer Nut Ed) if you have any ideas for improvement
  #12
Old 08-23-2009, 04:16 PM
Tron5 Tron5 is offline
1995 E34 TDS A
From your link, it appears that the bolt that goes in the seat rail to fasten the wire is NLA. I will look in a junkyard for this part.
What I am interested in knowing, is the mechanism which holds the wire tight (and subsequently moves the adjuster) inside the black wheel on the floor or is it in the b-pillar adjusting device?
Is it part no. 9 in the b-pillar or is it part no. 17 on the floor, from your link?
  #13
Old 08-23-2009, 04:34 PM
E34-520iSE E34-520iSE is offline
1990 E34 520iSE M20 - North East UK
Major Contributor
Send a message via Yahoo to E34-520iSE
The black wheel block is mounted on the floor. If you find an E34 at the breakers you will be able to see how it all works when you pry the small retaining clips out.
Regards,
Shaun M
__________________
  #14
Old 08-23-2009, 10:53 PM
11/1988 E32 750iL
5-10 Grand Master
apparently the pics I attached do not work. Here once more, the black wheel under the seat is the one which makes it all
here seat fully back, see the red arrow
http://tinypic.com/usermedia.php?uo=...sKG4h4l5k2TGxc
here the seat fully forward, see the red arrow
http://tinypic.com/usermedia.php?uo=...Bmc4h4l5k2TGxc
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
