M20 Bleeding experience by moots:
Just to share a simple method to bleed the cooling system.I really cannot comprehend why we need to bleed,bleed and re-bleed the cooling system after every maintenence.I did this after replacing the
thermostat and flushing the coolant:
(Mine's an m20 engine with the reservoir by the side of the rad)
1.Fill up the rad with the plastic bleeder screw(on reservoir) and metal bleeder screw(on t-stat housing),open.
2.When full,put a finger over the reservoir bleed hole and blow,yes,blow into the reservoir filler neck.(we are basically pressurising the system)
3.When water flows out of the t-stat housing bleed hole,tighten the screw.
4.Top up reservoir if required.
5.Now blow again until coolant exits the reservoir bleed hole and tighten when bubble free.
6.Top up coolant to the cold/kalt mark,tighten cap.You're done. No more bleeding required as all air is purged from the system. I have done this 4 times on three cars and it worked like a charm.
