Nice dude
I put it in about 1 month ago and was getting noise when the car was on. I talked about this in another thread, but it was lost when the server went down. Today I turned down the gains from 75% to about 30% for the front and rear. Problem solved, no noise what-so-ever. I couldn't belive it. Before I would get clipping at around 60% on the head deck. Now clipping is around 95%. The sub is a free air 12". For bass duties it's okay. My impressions are that the rear trunk muffles a lot of the bass, meaning with the trunk open the bass is a lot louder from outside the cabin. With the rear arm rest down bass spl is improved a bit (noticable), not dramatic at all. maybe its getting 100wrms and the sub is rated for 150wrms. It's easy to make the sub clip (which is bad). hmm. I'm not looking forbass (car shaking), I don't get it. A lot better than stock, it's like a nightclub in here. All road noise is suppressed and the music is clear. I did all the work myself, total time maybe 80 to 100 hours. I hate the 4 picture limit per post.
Nice dude
89 535 272,000km auto Euro
looks good, but from what i've found that not the best place for a sub... maybe a free air sub is different, but when i had trouble hearing bass from the trunk i cut out the ski panel and mounted a 10" MTX in a sealed box right where you have yours... but it was pretty pathetic, the bass was almost non-existent..
so i moved it to the rear-right corner of the trunk, held still with velcro, and the bass became significantly stronger ... now a single 10" is enough to do the whole car!
yeah, i also question these free air subs,
if i was you kriss, i would also try it in a fully
sealed box. i think you might be surprised
originally by Rollingon20strong:
hey thanks jeff for the info good LOOking out
aka Dan and that cat ja ja ja takes care of my baby jaja
while you'll probably get better results with a sealed sub in the spare wheel area, it's probably gonna be pretty tight for a 15"... and you kinda need the spare wheel...
do you know someone with a sealed boxed sub that you can try? if the difference is significant (as it was for me), then it would be worthwhile building a box for your current sub that fits the car and is close enough to the manufacturer's enclosure size specs... i built the box for mine at the cost of about $40AUD ($25US).. not pretty but a lot cheaper than a premade one, and you can build it to specifications which helps more than i realised...
the 15" sub might fit in the spare wheel area, but i think it would need a bigger enclosure to operate well.. from what i remember a 15" sub needs at least 250L, where a 10" needs less than 70L, depending on the model of sub
so while it may sound better than your current setup, the sub will be limited and will still sound better in a box
congradulations on ur work ... so u didnt need to put the grounds off the battery? if u use insulator transofrmers u can go to 75% I use gain around 80% for better bass ... also have no noise.
